TwinTurbo.NET: Nissan 300ZX forum - I bet timing belt is off
Subject I bet timing belt is off
Posted by ThisIsSparTTa on October 25, 2016 at 11:34 AM
  This message has been viewed 252 times.
In Reply To Tips on finding why I have no compression posted by FL300zx on October 21, 2016 at 01:44 PM
Message Either timing belt was installed incorrectly, or it slipped. On mine, it was off 1 tooth at the crank, which caused weird low (but not 0) compression numbers, and would run okay until about half throttle, then just bog. Best case in that situation is you'll need to redo timing belt, worst case is the timing belt slip let your valves slam into your pistons, and you'll at least be getting your heads rebuilt.
