TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pump relay bypass?
Subject Re: Fuel pump relay bypass?
Posted by Cjw3 on October 21, 2016 at 8:15 PM
  This message has been viewed 763 times.
In Reply To Fuel pump relay bypass? posted by hunterg on October 21, 2016 at 11:53 AM
Message [ http://www.ttxtz.com/images/ECCS_colored_m.gif ]
The B/P wire at #16 on the ECU will be pulled low to cause the Pump relay to latch in.. If the White/Black Wire feeding the Relay is not hot, then the relay has no power to give to the ECU so it can't latch in..
That White/Black wire gets it's power from the Fuseable Link at the Battery Connection.. Far right on the Print
Check there..
Cj
