TwinTurbo.NET: Nissan 300ZX forum - ??? Engine bolted to the chassis, and plop the engine in??>
Subject ??? Engine bolted to the chassis, and plop the engine in??>
Posted by ZUL8TR on October 18, 2016 at 5:12 AM
  This message has been viewed 251 times.
In Reply To Re: Engine install without removal of trans? posted by Smokiedabear on October 17, 2016 at 01:03 PM
Message That doesn't make any sense, and you repeat it in your last post. If you really mean leave the tranny bolted to the chassis it will not be easy to line up the engine with the tranny input shaft because it will be difficult to wiggle the engine and and rotate the crank to line up with the tranny shaft. If the rear wheels are off the floor you could have someone rotate the tires a bit to help the line up. Otherwise disconnect the drive shaft so you have access to the tranny rear to rotate the input shaft for line up.
If you get it done your way let us know the details.
ZUL8TR in Orlando,FL
