TwinTurbo.NET: Nissan 300ZX forum - Manual Transmission Swap ?
Subject Manual Transmission Swap ?
Posted by Bad Fish on October 07, 2016 at 1:42 PM
  This message has been viewed 321 times.
Message I am finishing up a manual transmission swap on a native twin turbo. When I mounted the clutch pedal I had to remove the shift interlock module and a relay that are located in the upper bolt hole used to secure the pedal assembly. I can't seem to find any good reference to the wiring module and relay in the factory wiring diagrams. My guess is that they can both be removed and the wires taped up under the dash but wanted to make sure that they are both strictly for the automatic transmission and nothing that I will still need.
Thanks
  • Manual Transmission Swap ? - Bad Fish 13:42:08 10/07/16
