TwinTurbo.NET: Nissan 300ZX forum - I use a funnel attached to a hose and route it from the >>
Subject I use a funnel attached to a hose and route it from the >>
Posted by ZUL8TR on October 07, 2016 at 2:45 AM
  This message has been viewed 244 times.
In Reply To When you do change the fluid, the 5 gallon sprayer method posted by Zblackbeast on October 05, 2016 at 10:32 AM
Message engine bay by the battery down to the tranny fill hole. Make sure the hose stays in the tranny fill hole (secure with what ever you think works). Then I dump 3 quarts in the tranny and plug up. No compressor needed just gravity. I drain old fluid out with car on level ground and jack up and secure to do the fill.
Note of caution, before draining old fluid FIRST remove the fill plug. If that can't be removed at least you will not be without a car to use till you get the fill plug out.
ZUL8TR in Orlando,FL
