TwinTurbo.NET: Nissan 300ZX forum - I just use a 3 qrt aluminum water container.
Subject I just use a 3 qrt aluminum water container.
Posted by white22sky on October 06, 2016 at 10:25 PM
  This message has been viewed 251 times.
In Reply To When you do change the fluid, the 5 gallon sprayer method posted by Zblackbeast on October 05, 2016 at 10:32 AM
Message Drill a hole in the cap and a hole near the top, seal them and insert preferred tubing. Then you can unscrew the cap fill with desired fluid cap back off and apply about 8 to 10 psi regulated is easiest and it will push the fluid right out which ever hose your not using to pressure the container with. Stick that end in the fill and your good to go. Whole setup costs less than 12 bucks and will have your manual transmission filled in less than a min. This does of course assume you have access to a compressor or pump.
" I told my son, you have to catch the football other wise this
just
looks like child abuse." - My brother
