TwinTurbo.NET: Nissan 300ZX forum - Perhaps an aftermarket system was added to he car along the
Subject Perhaps an aftermarket system was added to he car along the
Posted by jzack on October 06, 2016 at 7:00 PM
  This message has been viewed 247 times.
In Reply To Keyless entry programming mode issue posted by ThatBlack300zx on October 06, 2016 at 03:23 PM
Message way? Here are some instructions I found if OEM:
Obtain all remote transmitters for this vehicle.
1. Open the trunk, sit in vehicle and close and Lock all doors.
2. Insert key into ignition and fully remove from ignition at least six times in 10 seconds. If you are having problems try varying the speed in which you put the key in and out of the ignition.
3. Manually Unlock and then Lock the driver's door using the knob on the door.
4. Press the LOCK button on the first remote to be programmed within 5 seconds of completing step 3.
5. To program additional remotes repeat step 3 and 4 for each remote. You can program up to 4 remotes to this vehicle.
6. Programming is now complete. Unlock driver's door manually using the door lock knob and open then close door.
7. Test all remotes to ensure proper programming.
