TwinTurbo.NET: Nissan 300ZX forum - Brake line lock information/advice request
Subject Brake line lock information/advice request
Posted by SammybTT(TN) on October 04, 2016 at 10:03 PM
  This message has been viewed 555 times.
Message So back in 2013 I was investigating a front brake line lock and I received some general information stating to install the solenoid in the line from the brake master cylinder line going to the ABS unit. The intent of this modification is for heating my tires up before racing
Today I called Summit to order a line lock and they told me not to use it with ABS. Later a fellow drag racer said it has to be installed after the ABS valve. If I go this route I would have to order 2 solenoid valves
Can some one that has installed a front brake line lock please provide:
1). Brand of solenoid valve and distributor?
2). Did you install before or after the ABS valve?
3). Line lock solenoid valve install location
4). Confirm the fitting is 10mmx1.0mm
5). Where did you installed activation switch and indicator light
6). Any additional information regarding the installation
Of course pictures are always welcomed!
Thanks for looking
Sammy
