TwinTurbo.NET: Nissan 300ZX forum - Hook up a fuel pressure gauge
Subject Hook up a fuel pressure gauge
Posted by Stanky on October 04, 2016 at 9:26 PM
  This message has been viewed 694 times.
In Reply To How to test fuel dampener and regulator? posted by FL300zx on October 04, 2016 at 09:54 AM
Message Hook it up after the fuel filter,before the fuel rail. start car and monitor fuel pressure, should be around 33psi. Then Disconnect the vaccum line from the regulator, fuel pressure should go to 43psi. Turn car off and monitor fuel pressure, if fuel pressure drops, re-prime system,turn car off, and block off the line after the regulator(going to the tank). If the pressure now does not drop, your regulator is bad.
"Lag", or hesitation can be caused by lots of things. I would first start by making sure all your connectors are properly connected and not corroded. Scan for codes? Based on what you've told us, I don't believe it's a fuel issue though
