TwinTurbo.NET: Nissan 300ZX forum - clean throttle bodies, reset the TPS, you also >>>
Subject clean throttle bodies, reset the TPS, you also >>>
Posted by ZUL8TR on September 24, 2016 at 5:02 AM
  This message has been viewed 640 times.
In Reply To Correct Idle Speed posted by Anath3ma on September 24, 2016 at 03:14 AM
Message can check the IAA system for idle cures:
Part 1 [ http://www.z-car.net/IdleTech.html ]
Part 2 [ http://www.z-car.net/IdleTech2.html ]
Sometimes idle issues can be cured with WD40
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=782765 ]
TPS adjust
Note once TPS adjusted turn ignition key to start position, unplug the gray connector for about 5 sec, then replug then turn off ignition. Now ready to start and go
[ http://z32.wikispaces.com/Throttle+Position+Sensor ]
Might as well check the throttle body sync
[ http://z32.wikispaces.com/Throttle+Body ]
ZUL8TR in Orlando,FL
