TwinTurbo.NET: Nissan 300ZX forum - Re: Leaking injector orings?
Subject Re: Leaking injector orings?
Posted by megaDan on September 19, 2016 at 9:12 AM
  This message has been viewed 303 times.
In Reply To Leaking injector orings? posted by -Grimm- on September 18, 2016 at 09:02 PM
Message Unfortunately I only have a WB02 on one side, I haven't taken the step to swap sides yet.
I didn't mention in my post, but I'm running a topfeed injector setup. I'm not sure how a leaking o-ring would cause it to run rich. It would have to be at the rail side, as the intake system is airtight up to 5PSI with a boost leak test.
I suppose its possible I have a massive boost leak that is very repeatably exposing itself only under boost. Heck, given how it started all of a sudden that might be the most likely scenario. Maybe I'll pull everything apart and put it back together.
