TwinTurbo.NET: Nissan 300ZX forum - Unless you've already tried this...jumper the wheel well
jzack
on September 10, 2016 at 12:36 PM
Re: The connectors behind the passenger side headlight are all
posted by MaxxAction
on September 10, 2016 at 09:06 AM
relay. That is, bypass the starter circuit connections with a little jumper wire. This tests that the relay contacts aren't having an issue.
No power to starter signal wire...
MaxxAction
00:17:51 09/10/16
jzack
08:27:19 09/10/16
MaxxAction
09:06:45 09/10/16
Unless you've already tried this...jumper the wheel well -
jzack
12:36:22 09/10/16
BTW - when you do this connect a meter to the jumper and see
jzack
12:51:27 09/10/16
Re: BTW - when you do this connect a meter to the jumper and see
MaxxAction
15:43:33 09/10/16
Best not to overthink the issue, break the issue down into
jzack
22:37:14 09/10/16
Re: Best not to overthink the issue, break the issue down into
MaxxAction
06:27:57 09/12/16
Turning the key all the way sounds like maybe an ignition
jzack
11:34:18 09/12/16
The car doesnt/didnt have an aftermarket alarm by chance? (n/m)
-Grimm-
13:23:32 09/12/16
Re: The car doesnt/didnt have an aftermarket alarm by chance?
MaxxAction
13:42:43 09/12/16
