TwinTurbo.NET: Nissan 300ZX forum - Re: 1990 n/a a/t many problems. Am I missing something
Subject Re: 1990 n/a a/t many problems. Am I missing something
Posted by Cjw3 on August 28, 2016 at 9:28 AM
  This message has been viewed 310 times.
In Reply To 1990 n/a a/t many problems. Am I missing something posted by 3car on August 28, 2016 at 07:42 AM
Message You have tossed a shit pot full of expensive parts at a car with no real Diagnosis of a problem..
CAS will only chew itself up if the Machined alignment was wrong from the Factory.. If you pull the CAS you will see the Marks on the Drive Pin.. And it's bearings will be shot.. That is New Head time.. Or find someone to align it for you
Timing Belt is every 60K or so..
Rear Main is only if leaking
Because so much stuff has been done to it I'd
Do a plenum pull and toss in Late Model Injectors with a Kit
Do a T-Body water Delete
Change out the Engine Wire Harness
Replace all Rubber hoses, fuel and water
Toss in a chipped ECU to allow for better fueling
Change the Knock Sensor and Sub Harness
My Three NA's have been a Joy.. Difficult to work on, but reliable and fun..
Cj
