TwinTurbo.NET: Nissan 300ZX forum - Re: Leaking cooliant
Subject Re: Leaking cooliant
Posted by timz on August 27, 2016 at 5:49 PM
  This message has been viewed 283 times.
In Reply To Leaking cooliant posted by vcj2 on August 27, 2016 at 12:47 PM
Message You can check where is the coolant leak fairly easy. Put the car on the hoist (or jack stands). Remove the bottom engine covers. Use a coolant pressure tester (you can rent it at Autozone) and pressurize the radiator to about 16psi (when it is cold!).
Then just look for the leak. I doubt it is the head gasket as the Z32 head gasket is very strong. (unless you overheated the car). Hope this help!
