TwinTurbo.NET: Nissan 300ZX forum - Is i somewhat tuned or are yoou on the basemap still?
Subject Is i somewhat tuned or are yoou on the basemap still?
Posted by kickerzx on August 27, 2016 at 1:58 AM
  This message has been viewed 314 times.
In Reply To Putting a vacuum on the wastegates is a good idea posted by dTb on August 26, 2016 at 07:17 PM
Message Aiso the timing IS calibrated? With the timinggun hooked up to a lead between the coil and the plug (not to the "timing loop" on the wiring)?
Are you sure BOTH turbos are spinning? If you unhook the pipes coming from them and rev the engine a little it should blow out both of them. You will probably also "hear" them if you shut the engine of and run to the pipes and listen for them spooling down. It should take a few seconds before they stop.
Your idlesystem... Is it complete and intact? Didnt disconnect any of it? Mainly thinking about the air regulator here. It needs power to heat up the bimetal to close up. Its grounded through the fuelpumprelay. If it doesnt close you will have a big boostleak going from the balancetube to the DS intake tubing.
