TwinTurbo.NET: Nissan 300ZX forum - Stock recircs are closed at a dP of roughly 2.5 PSI or lower
Subject Stock recircs are closed at a dP of roughly 2.5 PSI or lower
Posted by LitlElvis on August 25, 2016 at 7:57 PM
  This message has been viewed 325 times.
In Reply To Right, I completely understand the function of them posted by dTb on August 25, 2016 at 06:57 PM
Message this would be the difference in pressure between the plenum and the intake piping where the recircs mount to. WOT will never produce this type of dP in this short of a distance unless there is some restriction other than the throttle valve between these two points... (overlooked rags stuck in intake pipes could possibly do this).
If you think they are open at WOT, the diaphragm in your recirc(s) could be ruptured - try applying 10 PSI to the hose nipple of each to see if they leak.
Also, make sure the vacuum hoses for the recircs are not restricted in any way.
