TwinTurbo.NET: Nissan 300ZX forum - Recircs are also exposed to boost at their diaphragm
Subject Recircs are also exposed to boost at their diaphragm
Posted by LitlElvis on August 25, 2016 at 2:21 PM
  This message has been viewed 344 times.
In Reply To Yah it idles and drives great, just no boost. posted by dTb on August 25, 2016 at 10:51 AM
Message when the the small hose is hooked up properly to reference boost/vacuum after the throttle body. If you don't provide pressure to the diaphragm at the same time as pressure to the inlet, then they're basically just a pop-off valve and will leak with very little pressure applied.
The diaphragm has a larger surface area than the valve and because of this, it will keep the valve closed under any boost pressure (when hooked up properly). They only open when there is a pressure differential between the diaphragm and the valve... like what you created when you applied boost to the valve side only.
