TwinTurbo.NET: Nissan 300ZX forum - Yah it idles and drives great, just no boost.
Subject Yah it idles and drives great, just no boost.
Posted by dTb on August 25, 2016 at 10:51 AM
  This message has been viewed 386 times.
In Reply To I bet your timing belt is right. Otherwise, it would idle posted by MixManMash on August 24, 2016 at 01:05 PM
Message I am running a MAP sensor so it will drive fine with leaks.. i did leak check all my boost hoses and turbos to 20psi but noticed that i had to apply pressure to the top of the recirc valves to get them to not leak. And they leak allot... Which is one thing i still don't understand... Aren't they supposed to when vacuum is being pulled by the engine? Seems like a catch 22; vacuum opens recircs, dumping flow from turbo, can't build boost because of that? I just ordered SSQVs to eliminate the recircs as the culprit.
