TwinTurbo.NET: Nissan 300ZX forum - Depends on your test conditions, but yes
Subject Depends on your test conditions, but yes
Posted by -Grimm- on August 25, 2016 at 9:45 AM
  This message has been viewed 228 times.
In Reply To Re: I would solder the subharness into the main harness posted by str86z on August 24, 2016 at 07:29 PM
Message Assuming you 100% tested all those items, including:
-Removing spark plug, ground to manifold, verify spark (rules out bad electrode, coil pack)
-Testing injector signal with noid light, verify injector cycling via battery (if its partially running your timing should be close enough for all cylinders to fire)
-Testing compression with all plugs removed, throttle open
Cant assume any single thing.
PTUs tend to fail warm, sometimes function cool. Wiring tends to vibrate loose.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
