TwinTurbo.NET: Nissan 300ZX forum - That is quite a bit of green stuff!
Subject That is quite a bit of green stuff!
Posted by Stokens (AR) on August 24, 2016 at 4:42 PM
  This message has been viewed 224 times.
In Reply To Re: Re: Z32 cylinder 1 & 2 dead posted by str86z on August 24, 2016 at 03:44 AM
Message See where that harness has a broken place in the rubber neck? That's where the moisture creeps in. My harness was green all the way back into the wires. Ended up pulling the engine and putting a brand new one in! Fire it up, then move the harness around and listen for a difference. Before my corrosion problem got too bad, I could move the harness back and forth (while plugged in of course), and could hear the cylinders dropping in and out!!
If I would have known addiction was this expensive
I would have seen a shrink a long time ago. --BadZCar (FL)
