TwinTurbo.NET: Nissan 300ZX forum - you've done all the Easy Stuff.. Now lets hunt..
Subject you've done all the Easy Stuff.. Now lets hunt..
Posted by Cjw3 on August 23, 2016 at 8:18 PM
  This message has been viewed 311 times.
In Reply To Z32 cylinder 1 & 2 dead posted by str86z on August 22, 2016 at 11:19 PM
Message From what you've said, you have everything needed to make the Cylinders Fire, but they are not..
1) You have Compression
2) You Have Fuel
3) You Have Spark
It Should be running..
If you have all Three Components to make it run and it's NOT, then the Spark is at the wrong time.. I can see no Other Conclusion from your Facts..
Pull the Coil Packs.. all six.. Lay them on the Plenum with Spark plugs in them.. With the Plugs Grounded.. Pull the CAS.. with the ignition switch on, rotate the CAS and watch the Firing Order of the Plugs.. It's 1-2-3-4-5-6.. I'm guessing SOMEHOW 3-4-5-6 is proper but 1-2 is somehow screwed up..
I can not see how that can happen.. but thats all I got..
Cj
