TwinTurbo.NET: Nissan 300ZX forum - Re: Not sure we can help much with this...you'll need to
Subject Re: Not sure we can help much with this...you'll need to
Posted by aretwodetwo on August 19, 2016 at 2:59 AM
  This message has been viewed 223 times.
In Reply To Not sure we can help much with this...you'll need to posted by jzack on August 18, 2016 at 11:46 PM
Message aac and ficd have different connectors based on where the connector "key" i guess youd call it is placed, either on the left or right of the connector.. correct me if im wrong on that. and im sure theyre not swapped. maf is a rebuilt maf from concept z performance so i trust their work. about the only thing i didnt replace was injector o rings, the plenum to injector seals are replaced but not the o rings which i should have done in the first place... im gonna pull off the plenum tomorrow and see what i find. maybe theyre worn out after 15 years of in-op
