TwinTurbo.NET: Nissan 300ZX forum - Not sure we can help much with this...you'll need to
Subject Not sure we can help much with this...you'll need to
Posted by jzack on August 18, 2016 at 11:46 PM
  This message has been viewed 252 times.
In Reply To Re: There are probably hundreds of post on starting trouble but posted by aretwodetwo on August 18, 2016 at 09:28 PM
Message carefully check ALL the sub-systems to make sure nothing was missed. Some examples, were the balance tube o-rings installed? Is the IACV operational? Is all good with the MAF? Is the ECU properly matched for this engine.
Yes it's PITA detective work, time consuming and not fun. On top if all this - do you have good confidence in the engine rebuild. I'd also try to check engine compression (yes, even tho a new rebuild) and perhaps do a leak down test?
Bottom line, we aren't there ... Can only give ideas on issue!
