TwinTurbo.NET: Nissan 300ZX forum - There are probably hundreds of post on starting trouble but
Subject There are probably hundreds of post on starting trouble but
Posted by YlwPrlZTT on August 18, 2016 at 8:12 PM
  This message has been viewed 238 times.
In Reply To Z will not start - ive literally tried everything!! posted by aretwodetwo on August 18, 2016 at 05:45 PM
Message again here it goes. Start with the 6 P's. When you said you've replaced all the connectors, have you actually replaced the EFI harness? Corrosion is a b* and if you have any on any connector it could cause a load of problems, ask me how I know :-\. Have you done a vacuum/boost leak check? You said the car has not ran for 15 years is that AFTER the engine rebuild or before, I know it's a dumb question but you never know. Have you checked timing (part of 6 P's)? It could literally be just about anything. Starts with the 6 P's and write what you found.
