TwinTurbo.NET: Nissan 300ZX forum - Re: fuel pump ???
Subject Re: fuel pump ???
Posted by aretwodetwo on August 18, 2016 at 6:13 PM
  This message has been viewed 268 times.
In Reply To fuel pump ??? posted by dave280zzz on August 18, 2016 at 05:04 PM
Message if you have one connect a data link connector and use a diagnostic program to active test the fuel pump. you could also run 12v to power the fuel pump from the battery just using a wire and ground with the key on to see if anything happens but thats pretty close to the gas tank and if there are fumes theres a risk of spark and explosions.. theres a fuel pump fuse "FL30A" in the small box to the left of the engine before the battery, check to make sure its not blown.
