TwinTurbo.NET: Nissan 300ZX forum - Re: FWIW- measuring good voltage doesn't mean the wire
Subject Re: FWIW- measuring good voltage doesn't mean the wire
Posted by Rasta420 on August 18, 2016 at 5:09 PM
  This message has been viewed 223 times.
In Reply To FWIW- measuring good voltage doesn't mean the wire posted by jzack on August 18, 2016 at 04:08 PM
Message Good to know, thanks.
I did Google high current wiring feed and read up on it, thats why I changed the starter harness.
I think it's got to be something minor I am overlooking since it worked fine then just failed, I have not mentioned yet but it is a 5sp swap with the electrics wired in from a couple different threads on here and elsewhere. Worked for years this way so hadn't considered it being an issue but now I am going to go through all wires and sensors this weekend to fix it. Mention it now because other than ignition switch the clutch switch, starter relay, fusible link, three fuses on the fusible link panel have been checked, neutral switch needs checked, ignition switch needs tested, and the wires from beginning of circuit to end of circuit have to be verified functioning.
I hate electrical gremlins...
91 2+2 NA Auto
90 2+0 TT, 5spd
