TwinTurbo.NET: Nissan 300ZX forum - There are other things besides the ignition that could cause
Subject There are other things besides the ignition that could cause
Posted by jzack on August 17, 2016 at 2:29 PM
  This message has been viewed 239 times.
In Reply To replacement harness didn't help, only thing left is ignition posted by Rasta420 on August 16, 2016 at 04:49 PM
Message this issue. The safety switch on the clutch pedal - check to be sure the nylon washer that pushes the switch isn't gone (they fall off). Also if the ignition switch turns and clicks the relay in the driver side (outside) wheel well, ignition switch should be ok.
