TwinTurbo.NET: Nissan 300ZX forum - Re: The service manual does not show a gasket seal on the >>>
Subject Re: The service manual does not show a gasket seal on the >>>
Posted by 1308cats on August 15, 2016 at 8:17 PM
  This message has been viewed 412 times.
In Reply To The service manual does not show a gasket seal on the >>> posted by ZUL8TR on August 14, 2016 at 05:53 AM
Message I have an FSM, it doesn't show a gasket because what I'm talking about is permanently attached to the lower belt cover. At least it used to be. It appears to be a bead of rubber like material that remains flexible after hardening so that when you tighten down cover, it conforms to the front of the engine block. This bead is about 1/8"+ in diameter so gasket maker won't hack it. FSM also doesn't show felt "gaskets" that go between upper timing belt covers and the back plates they bolt onto.
