TwinTurbo.NET: Nissan 300ZX forum - The infamous starter relay.....? (n/m)
FrozTTy
on August 15, 2016 at 7:12 AM
91 NA MT no crank
posted by Rasta420
on August 14, 2016 at 04:22 PM
91 NA MT no crank
Rasta420
16:22:43 08/14/16
If you get a no start when jumpering the solenoid via the
jzack
21:22:07 08/14/16
Re: If you get a no start when jumpering the solenoid via the
Rasta420
07:25:39 08/15/16
Rained all day yesterday, did get a replacement
Rasta420
06:49:25 08/16/16
replacement harness didn't help, only thing left is ignition
Rasta420
16:49:35 08/16/16
There are other things besides the ignition that could cause
jzack
14:29:20 08/17/16
thanks, I'll be chasing the circuit from beginning to end
Rasta420
07:03:44 08/18/16
FWIW- measuring good voltage doesn't mean the wire
jzack
16:08:34 08/18/16
Re: FWIW- measuring good voltage doesn't mean the wire
Rasta420
17:09:57 08/18/16
Yep and it's usually something really stupid...lol (n/m)
jzack
20:18:59 08/18/16
SOLVED...sketchy wiring from clutch switch to harness
Rasta420
10:35:36 08/21/16
The infamous starter relay.....? (n/m) -
FrozTTy
07:12:47 08/15/16
Re: The infamous starter relay.....?
Rasta420
07:23:46 08/15/16
The starter relay in the the drivers side wheel well right? (n/m)
white22sky
09:44:02 08/15/16
Yes (n/m)
Rasta420
14:40:42 08/15/16
