TwinTurbo.NET: Nissan 300ZX forum - Not with out Problems
Subject Not with out Problems
Posted by Cjw3 on August 08, 2016 at 7:16 PM
  This message has been viewed 295 times.
In Reply To ECU Question posted by Mglide86 on August 08, 2016 at 03:36 PM
Message 1) Na ECU's do not control the TT Fuel Pump Controller Properly.
2) Na ECU's do not have the Additional Fan Outputs TT's have
3) Na ECU's do not have Outputs for the Boost Sols..
If the 91 TT is a Native TT, then you'll have problems..
If you run a NA FCU, Aux Control the Fans, and do not use the boost Sols.. your Golden using a NA ECU with a TT Prom.
If the 91 is a Transplant TT in a Na Chasis, then run a TT Prom in the NA ECU and handle Problems two and three listed above.. Number One is no longer an issue..
Cj
