TwinTurbo.NET: Nissan 300ZX forum - Disconnect your battery...
Subject Disconnect your battery...
Posted by DVDBURN (MD) on August 01, 2016 at 9:16 PM
  This message has been viewed 386 times.
In Reply To Just noticed I'm seeing 5+ volts from TPS posted by Barry (NJ) on August 01, 2016 at 06:58 PM
Message and remove the ECU harness connector from the ECU. Remove the bottom cover of your ECU. Use a #2 cross-tip screwdriver and unscrew all the screws that hold the Main board in by two or three threads. Then screw them back in real tight. You may have noticed that the screws closest to the harness connector were slightly loose at first.
www.mytwinturbo.com
Nissan Data Voice on YouTube
