TwinTurbo.NET: Nissan 300ZX forum - TPS is a variable resistor acting as a simple
Subject TPS is a variable resistor acting as a simple
Posted by jzack on August 01, 2016 at 8:25 PM
  This message has been viewed 326 times.
In Reply To Just noticed I'm seeing 5+ volts from TPS posted by Barry (NJ) on August 01, 2016 at 06:58 PM
Message voltage divider. One side of the divider may not be grounded. That would always give the same voltage reading regardless of TPS position. Check your harness connections on both the TPS near and far ends.
