TwinTurbo.NET: Nissan 300ZX forum - TPS must be adj on car before
BarryGZX
on August 01, 2016 at 1:27 AM
Re: I got some more ideas
posted by Captconan
on July 31, 2016 at 08:20 PM
you calibrate in Haltech and you really should be running 2 widebands and remove those narrowbands
Wits end here. Z stalls when blipping throttle at idle.
Captconan
21:38:33 07/29/16
check for DTC's? (n/m)
BarryGZX
00:41:47 07/30/16
Have you ever had this car run well?
Cjw3
09:19:27 07/30/16
Re: Have you ever had this car run well?
Captconan
17:22:06 07/30/16
Have you had this tuned professionally? With a standalone,
MixManMash
21:01:23 07/31/16
Re: Have you had this tuned professionally? With a standalone,
Captconan
22:08:00 07/31/16
Before Haltech? Then that's your problem. (n/m)
MixManMash
21:39:57 08/01/16
Re: Wits end here. Z stalls when blipping throttle at idle.
Captconan
17:20:27 07/30/16
TPS adjusted? (n/m)
BarryGZX
18:01:21 07/30/16
Re: TPS adjusted?
Captconan
23:00:27 07/30/16
Re: Re: TPS adjusted?
BarryGZX
01:12:00 07/31/16
Re: Re: Re: TPS adjusted?
Captconan
11:27:18 07/31/16
follow these steps
BarryGZX
13:41:13 07/31/16
Re: follow these steps
Captconan
15:25:54 07/31/16
ok
BarryGZX
01:19:30 08/01/16
Re: ok
Captconan
10:37:54 08/01/16
I think the 6Ps still are valid
Carlos Ramirez
19:26:10 07/30/16
Re: I think the 6Ps still are valid
Captconan
22:59:40 07/30/16
Re: Re: I think the 6Ps still are valid
MaxxAction
17:10:33 07/31/16
Re: Re: Re: I think the 6Ps still are valid
Captconan
17:28:32 07/31/16
Re: Re: Re: Re: I think the 6Ps still are valid
MaxxAction
08:16:32 08/01/16
Re: Re: Re: Re: Re: I think the 6Ps still are valid
Captconan
10:39:46 08/01/16
Re: Re: Re: Re: Re: Re: I think the 6Ps still are valid
MaxxAction
11:49:27 08/01/16
My car did this as well, ended up being the TPS (n/m)
-Grimm-
15:41:22 07/31/16
Re: My car did this as well, ended up being the TPS
Captconan
17:29:31 07/31/16
Had to replace it
-Grimm-
14:39:32 08/01/16
Carlos Ramirez
19:21:46 07/31/16
Captconan
20:20:50 07/31/16
TPS must be adj on car before -
BarryGZX
01:27:02 08/01/16
MAP sensor
BarryGZX
01:43:18 08/01/16
Any reason your timing is at 17° instead of 15°? (n/m)
doug8867
05:57:42 08/01/16
Re: Any reason your timing is at 17° instead of 15°?
Captconan
08:14:55 08/01/16
