TwinTurbo.NET: Nissan 300ZX forum - Re: follow these steps
Captconan
on July 31, 2016 at 3:25 PM
follow these steps
posted by BarryGZX
on July 31, 2016 at 01:41 PM
What I'm saying is that there is no wetting voltage on the harness side for the hard idle. How does the ECU know the hard idle is on without that?
Wits end here. Z stalls when blipping throttle at idle.
Captconan
21:38:33 07/29/16
check for DTC's? (n/m)
BarryGZX
00:41:47 07/30/16
Have you ever had this car run well?
Cjw3
09:19:27 07/30/16
Re: Have you ever had this car run well?
Captconan
17:22:06 07/30/16
Have you had this tuned professionally? With a standalone,
MixManMash
21:01:23 07/31/16
Re: Have you had this tuned professionally? With a standalone,
Captconan
22:08:00 07/31/16
Before Haltech? Then that's your problem. (n/m)
MixManMash
21:39:57 08/01/16
Re: Wits end here. Z stalls when blipping throttle at idle.
Captconan
17:20:27 07/30/16
TPS adjusted? (n/m)
BarryGZX
18:01:21 07/30/16
Re: TPS adjusted?
Captconan
23:00:27 07/30/16
Re: Re: TPS adjusted?
BarryGZX
01:12:00 07/31/16
Re: Re: Re: TPS adjusted?
Captconan
11:27:18 07/31/16
follow these steps
BarryGZX
13:41:13 07/31/16
Re: follow these steps -
Captconan
15:25:54 07/31/16
ok
BarryGZX
01:19:30 08/01/16
Re: ok
Captconan
10:37:54 08/01/16
I think the 6Ps still are valid
Carlos Ramirez
19:26:10 07/30/16
Re: I think the 6Ps still are valid
Captconan
22:59:40 07/30/16
Re: Re: I think the 6Ps still are valid
MaxxAction
17:10:33 07/31/16
Re: Re: Re: I think the 6Ps still are valid
Captconan
17:28:32 07/31/16
Re: Re: Re: Re: I think the 6Ps still are valid
MaxxAction
08:16:32 08/01/16
Re: Re: Re: Re: Re: I think the 6Ps still are valid
Captconan
10:39:46 08/01/16
Re: Re: Re: Re: Re: Re: I think the 6Ps still are valid
MaxxAction
11:49:27 08/01/16
My car did this as well, ended up being the TPS (n/m)
-Grimm-
15:41:22 07/31/16
Re: My car did this as well, ended up being the TPS
Captconan
17:29:31 07/31/16
Had to replace it
-Grimm-
14:39:32 08/01/16
I got some more ideas
Carlos Ramirez
19:21:46 07/31/16
Re: I got some more ideas
Captconan
20:20:50 07/31/16
TPS must be adj on car before
BarryGZX
01:27:02 08/01/16
MAP sensor
BarryGZX
01:43:18 08/01/16
Any reason your timing is at 17° instead of 15°? (n/m)
doug8867
05:57:42 08/01/16
Re: Any reason your timing is at 17° instead of 15°?
Captconan
08:14:55 08/01/16
