TwinTurbo.NET: Nissan 300ZX forum - If I'm not mistaken, with two separate intakes the
Subject If I'm not mistaken, with two separate intakes the
Posted by puchy on July 28, 2016 at 2:56 PM
  This message has been viewed 203 times.
In Reply To Re: Re: Re: You need both MAFs plugged in and translator on ADD posted by Tylerw1 on July 25, 2016 at 05:15 AM
Message idle is controlled from the driver's side MAF only, because that's where the idle controller's air line is connected to. In another words the passenger side is not sucking air at idle unless you crack open the TB manually.
