TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Wastegate adjustable spring problem
Subject Re: Re: Wastegate adjustable spring problem
Posted by irdhp on July 27, 2016 at 10:57 AM
  This message has been viewed 235 times.
In Reply To Re: Wastegate adjustable spring problem posted by backinblack626 on July 25, 2016 at 12:59 AM
Message Wastegate are adjustable Kinugawa with a 1 bar(yellow) spring.
The spring is new.
I'm only running with spring pressure now.
There was air coming out from one of the actuators around where you screw the bottom and top part together.
I have tested the wastegate. Both open at around 8-9 psi. Could it be that the 1 bar spring isn't 1 bar and is a production error or something.
I noticed that the arm on the passage side didn't move as much as the driver side. Does that affect something?
