TwinTurbo.NET: Nissan 300ZX forum - Sorry, should have also said to pull each coil pack and
jzack
on July 24, 2016 at 1:28 AM
Could test the injectors thru the ECU connector but much
posted by jzack
on July 24, 2016 at 01:25 AM
Visually verify no spark using a spare plug (grounded) while cranking the engine. Eliminate the coil packs as the issue unless you've already done that.
A friend started his Z for the first time in 3 years:
Stokens (AR)
20:49:23 07/23/16
jzack
01:25:07 07/24/16
Sorry, should have also said to pull each coil pack and -
jzack
01:28:42 07/24/16
Sounds like the timing belt is hitting the timing cover. (n/m)
nonstopna
00:06:39 07/26/16
Good thought!
Stokens (AR)
13:52:12 07/26/16
