TwinTurbo.NET: Nissan 300ZX forum - jwt 500 cams
Subject jwt 500 cams
Posted by dfenton2 on July 23, 2016 at 6:51 PM
  This message has been viewed 459 times.
In Reply To Re: Re: ^ this. You clearly do not have the expertise or knowledge posted by Alooshi on July 23, 2016 at 04:50 PM
Message As for the sleeve, anything is possible. Just have to provide enough green to the right person in order to acheve the results you want. You can get 850 horse reliably with 87 87.5 88 and 89 bore pistons. All are good for the block without sleeving. Pair that with the correct breathers and garret 2860 or 2863 turbos and your off to the races. But again. 30+k in parts and engine alone for that build.
Plus then you need to prep the chassis for the extra power. It is a lot of work.
