TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Illumination fuse, in block left of clutch pedal. This is
Subject Re: Re: Illumination fuse, in block left of clutch pedal. This is
Posted by phzuidema on July 20, 2016 at 12:35 PM
  This message has been viewed 201 times.
In Reply To Re: Illumination fuse, in block left of clutch pedal. This is posted by Jok3r1552 on July 17, 2016 at 05:56 AM
Message Check your fuse(s) first. I had this issue. I replaced a perfectly good fuse (tested with an ohm meter), with a new one in a state of frustration, and now they worked!
Later had the same problem but my "fix" no longer worked. Turns out my fusebox blade contacts had spread over the last 25 years. My mechanic removed the fuse box, and re-bent all the connectors. Problem solved.
