TwinTurbo.NET: Nissan 300ZX forum - Re: How are the 2 separate sensors connected to the ECU?
Subject Re: How are the 2 separate sensors connected to the ECU?
Posted by RenegadeZ on July 18, 2016 at 5:40 PM
  This message has been viewed 250 times.
In Reply To How are the 2 separate sensors connected to the ECU? posted by jzack on July 18, 2016 at 05:24 PM
Message Sorry I wasn't clear.
There are two sensors only 1 of which is connected at any time.
Both are disconnected during the test. Just looking for someone to get the resistance on the wiring harness itself (not the knock sensor resistance).
Effectively it would be the resistance from pin 23 to ground on the ECU itself.
Hope this clears it up. Should go very quick if you can locate the connector.
