TwinTurbo.NET: Nissan 300ZX forum - Re: Building a 800hp Engine (Challenge Accepted!)
Subject Re: Building a 800hp Engine (Challenge Accepted!)
Posted by Alooshi on July 17, 2016 at 10:29 PM
  This message has been viewed 1232 times.
In Reply To Building a 800hp Engine (Challenge Accepted!) posted by Alooshi on July 17, 2016 at 10:16 PM
Message There is a guy in Australia who built the Z32 with the below specs. If I could, I would love to build the same and see how it does. What do you think?
BLACK BEAST (Australia from [ www.aus300zx.com ])
SLICKTOP TT R-SPEC
565RWKW @ 5800RPM - 30PSI
460RWKW &1000NM TQ @ 4500RPM
ENGINE
Beast Race Spec Stage 1
SERIES 2 MOTOR
RACE PORTED HEADS
CHAMBERS RELIEVED AND BORE MATCHED
FERREA 1mm OS VALVES
FERREA DUAL VALVE SPRINGS
FERREA TITANIUM RETAINERS
VITON VALVE STEM SEALS
JUN 66 264/9.5 CAMS
BDE INTAKE GEAR SPROCKETS
BDE EXHAUST CAM GEARS
GATES RACING KEVLAR TIMING BELT
TOMEI METAL HEAD GASKETS
BLOCK TORQUE PLATE BORED/HONED TO 88MM
WATER GALLERIES DRILLED/DEBURRED
CRANK KNIFE EDGED/BALANCED/MICOPOLISHED
CRANK PULLEY & FLYWHEEL BALANCED TO CRANK
EAGLE RODS
CUSTOM WISECO PISTONS CERAMIC COATED
(ALL PARTS CRYOTREATED AND BALANCED)
ACL RACE BEARINGS
NEW OEM OIL PUMP
PLENUMS PORTED/HONED AND MATCH PORTED
TWIN K&N XTREAM FILTERS
GTX2863R TURBOS 3" INTAKES
Z1 58mm THROTTLEBODIES
TDMWORKS FMIC + 2.5" PIPING
TURBOSMART 50mm RACE PORT BOV's
CUSTOM ROSS U/D RACE DAMPNER 4.8kg
GREDDY OS RACING PULLEYS
BDE ENGINE MOUNTS
CUSTOM STAINLESS TURBO WATER LINES
TWIN 19 ROW OIL COOLERS -10AN smic locations
GREDDY THERMOSTATED SANDWICH PLATE 10AN
POWER STEERING 7 ROW COOLER
N/A POWERSTEERING PUMP
ASI RADIATOR 56MM
SZ HIGH VOLUME OIL SUMP
CUSTOM OIL CATCH/BREATHER AND WATER OVERFLOW TANK
PENRITE RACING OIL
PARTS CERAMIC/HPC COATED
FUEL
MATTZ TOPFEED FUELRAIL
ID1300CC INJECTORS
CUSTOM 4 litre BAFFLED FUEL SURGETANK
WALBRO 400LPH LIFT PUMP
TWIN BOSCH 044'S -8AN FUEL LINE
FUELAB FUEL REGULATOR -8AN
A1 FUEL FILTER 40 MICRON
8AN ALUMINIUM FUEL LINE AND TEFLON HOSES/FITTINGS
ZEITRONIX ETHANOL SENSOR
FUEL COOLER
FLEX FUEL 98 TO E85
WHEELS
TE37 SUPERLAP
18 X 10 +20 275/35 R888
18 X 11 +18 315/30 R888
BODY
JET BLACK
MODIFIED 35mm SPL WIDE/VENTED FRONT GUARDS
CUSTOM 45mm REAR METAL WIDE BODY
MODIFIED UAS/GREDDY FRONT BAR FOR WIDEBODY
MODIFIED TWINZ REAR BAR/DIFFUSER FOR WIDEBODY
CUSTOM UNDERTRAY FOR TWINZ BAR DIFFUSER
STILLEN TYPE III SKIRTS AND DOOR FILLERS
BORDER VENTED BONNET
AEROCATCH BONNET PINS
C/F VENTED NOSE PANEL
CUSTOM AIRTRAY
GANADOR C/F MIRRORS
POWERTRIX FOG LIGHT DUCTS
APR GTC-300 1700mm CARBON WING +REINFORCED HATCH
CUSTOM FRONT SPILTTER WITH APR SUPPORTING RODS
CUSTOM TOW HOOKS
SUSPENSION
RE TEIN COILOVERS CUSTOM SPEC (ex UAS slotcar)
EDFC
IKEYA FORMULA FRONT LOWER ARM
IKEYA FORMULA REAR LOWER ARM
IKEYA FORMULA TENSION RODS
TUNE AGENT TRACTION RODS
UAS FRONT UPPER PIVOTING CAMBER ARMS
DRIFT SPEC REAR UPPER CAMBER ARMS
UAS HICAS ELIMINATOR (midori style)
SUPER PRO BUSHES diff ,sway bars,steering
SPL ALLOY SUBFRAME BUSHES
OKUYAMA CARBING FRONT STRUT BRACE
SPL FRONT FENDER BRACES
UAS RADIUS ROD SUPPORT BRACE
STOCK SWAYBARS
MODIFIED CHASSIS PIVOT POINTS FOR ROLL CENTRES
UAS CUSTOM BILLET TIE RODENDS
BRAKES
STOPTECH FRONT 355MM SLOTTED
STOPTECH REAR 328MM SLOTTED
FERODO DS2500 PADS
CHILI MASTER CYLINDER BRACE
MOTUL RBF 600 BRAKE FLUID
UAS BRAKE AIRDUCTS
INTERIOR
COBRA SUZUKA PRO GT SEATS
COBRA ALLOY SEAT MOUNTS
CROW 5 POINT RACE HARNESSES SFI 16.1 APPROVED
MOMO COMPETITION WHEEL
NRG SHORT BOSS QUICK RELEASE
CARBON FIBER VINYL TRIMMING
6 POINT CAMS SPEC ROLL CAGE with full interior
AVT RACE PEDALS
FIRE EXTINGUISHER
DRIVECHAIN
PPG HELICAL DOG BOX
PST CARBON TAILSHAFT
COMPETITION TWINPLATE CLUTCH
MODIFIED STOCK SHORT SHIFTER
LEADERS GEARS 4.10
QUAIFE LSD
UAS CLUTCH LINE
PENRITE GEARBOX & DIFF OIL
EXHAUST
MIKE SMITH MANIFOLDS ceramic coated
AMS 3" DUMPS ceramic coated
AMS 3" TEST PIPES
SZ 3" CATBACK -XPIPE WITH DUAL TIP MUFFLERS
ELECTRICAL
HALTECH PLATINUM PRO
HALTECH I/O EXPANDER BOX
HALTECH DUAL WIDEBAND
HKS TWIN POWER IGNITION
ZEITRONIX ETHANOL ANALYSER KIT
SSB LITHIUM BATTERY 2.5KG 900CC
VEI DUAL AFR GAUGE
DEFI RACER 60mm WATER TEMP
DEFI RACER 60mm OIL TEMP
DEFI RACER 52mm OIL PRESSURE
DEFI RACER 52mm EXT TEMP
DEFI RACER 52mm FUEL TEMP
DEFI RACER 52mm FUEL PRESSURE
DEFI RACER 52mm BOOST GUAGE
DEFI RACER 52mm VOLTS GUAGE
BLITZ SBC DUAL BOOST CONTROLLER
POWER ISOLATOR SWITCH
