TwinTurbo.NET: Nissan 300ZX forum - Check your switches down by the brake and
Subject Check your switches down by the brake and
Posted by white22sky on July 13, 2016 at 2:31 PM
  This message has been viewed 225 times.
In Reply To Cruise Control Disengages Sporadically posted by phzuidema on July 13, 2016 at 02:23 PM
Message clutch pedal. Make sure they are adjusted correctly and wiring is in place. Check the green pads while your down there too. Its also possible the switch or switches are failing. You can resistance test those.
I'd start there, those are the most common culprits. If it would turn out to be the unit itself under the hood, I've got several replacement ones should you need.
" I told my son, you have to catch the football other wise this
just
looks like child abuse." - My brother
