TwinTurbo.NET: Nissan 300ZX forum - Is there any chance one of the new turbos is causing the
Subject Is there any chance one of the new turbos is causing the
Posted by jzack on July 10, 2016 at 9:31 AM
  This message has been viewed 310 times.
In Reply To Re: how much coolant for your initial fill? maybe it is still posted by Fixntofly on July 09, 2016 at 09:29 PM
Message leak? I'm not even sure this is possible but it's one if the new things added to a good working engine. Even less likely, was a coolant and oil line cross connected during the servicing?
One way to verify on the issue -- drain the oil and inspect further that way - visually or by having a sample tested for contaminants.
Once you figure out what happened it would be good to post back on the situation. This could help others using search. FYI- this post will lock after a few days so just start a new thread and reference link back to this one.
