TwinTurbo.NET: Nissan 300ZX forum - Coolant leaking into oil without engine running
Subject Coolant leaking into oil without engine running
Posted by Fixntofly on July 09, 2016 at 7:57 PM
  This message has been viewed 393 times.
Message I have a 91 TT that I just had the engine out and upgraded turbos, removed the egr, performed coolant bypass mod, and did 120k timing items. I have noticed my coolant getting low but only dropping about 3" down in the radiator I'm running Evans waterless coolant so you can't see it in the oil but I noticed today that the oil level is going up and my oil pressure seams less when it's warmed up.
There was no coolant leak into the oil before I pulled the engine and I know I did not overheat the engine since the install my question is besides internal the engine ( head gasket, crack in heads or block) is there any other way for the coolant to get into the oil.
Also the car does not smoke at all no blue or black smoke?
The strange thing is I filled the coolant yesterday and did not start the car but today it was back down about 3" in the radiator with nothing on the floor????
Please help any info would help
Thanks
