TwinTurbo.NET: Nissan 300ZX forum - Is the ECU an actual TT ECU? If its not a native TT
Subject Is the ECU an actual TT ECU? If its not a native TT
Posted by CmyZ on July 08, 2016 at 9:03 PM
  This message has been viewed 288 times.
In Reply To ac cluster blinking posted by hixso on July 08, 2016 at 07:32 PM
Message ECU, like if its a NA chipped with a TT tune chip. It will not work. The TT and NA ECU are different in order to run the 3 speed fuel pump TT controller and the 2 speed TT AC condenser fan.
This was verified by DVD BURN (Gary) our resident electronics expert.
You probably tapped into another circuit... thinking it was the same... Can you just cut the wire in an easy place to verify if the AC and fuel gauge return to work properly. I hope you did not burn a circuit in the ECU... lol.. Good luck
