TwinTurbo.NET: Nissan 300ZX forum - I have the Same Problem. TPS and Switch are off Set
Subject I have the Same Problem. TPS and Switch are off Set
Posted by Cjw3 on July 04, 2016 at 9:04 AM
  This message has been viewed 391 times.
In Reply To Help me understand what you are talking about. (n/m) posted by madkiwi on July 03, 2016 at 11:46 AM
Message I think it's a problem with Manufacture, as there is no external means to adjust the TPS Sensor from the TPS Switch.
I'm running my 'Offset TPS Switch' and the only symptom is an excessively Rich progressing off Idle Stumble.. I think that is because the TPS Analog Signal is now not calibrated properly for a smooth progression From Idle to Running. The Enrichment Calculations put in too much fuel.
Cj
