TwinTurbo.NET: Nissan 300ZX forum - Cam bolts rubbing CAS bracket?
Subject Cam bolts rubbing CAS bracket?
Posted by dogpile on July 03, 2016 at 7:47 PM
  This message has been viewed 376 times.
Message I don't recall ever seeing this before over the years, so why wouldn't I see it first on my own car.
You can see the 4 bolts are rubbing, as is the cam gear itself.
Am I missing something? Those bolts are still tight (left cam gears on the heads when I pulled them - I'll deal with that part of the build later) and appear to be OEM as far as I can tell - if they're not, dude changed all 8 with a set of matching bolts...which is not the style that the rest of the motor went together in.
