TwinTurbo.NET: Nissan 300ZX forum - Yes if they're stuck open, OEM ones a $5 so I'd replace them
Subject Yes if they're stuck open, OEM ones a $5 so I'd replace them
Posted by Stanky on June 29, 2016 at 9:18 PM
  This message has been viewed 252 times.
In Reply To What about bad PCV valves, could they cause this? (n/m) posted by YlwPrlZTT on June 29, 2016 at 07:22 PM
Message How much PSI are you using to boost leak test? If you have the stock PCV system you should not be going more than 5psi.
Id do a compression test just to verify how all the cylinders are doing, and go from there.
