TwinTurbo.NET: Nissan 300ZX forum - Re: Unfortunately I've been using a standard flare nut wrench
Subject Re: Unfortunately I've been using a standard flare nut wrench
Posted by Z32_Tree_Killer on June 25, 2016 at 11:29 PM
  This message has been viewed 330 times.
In Reply To Unfortunately I've been using a standard flare nut wrench posted by tcutchall on June 25, 2016 at 11:08 PM
Message I would HIGHLY SUGGEST going to Ace Hardware, Menards, HomeDepot, etc.... and buying a torch if you don't already have one. If that "fancy wrench" doesn't get the job done that means you striped the nut... which means you will be dealing with a much more complicated project than you need. You should be able to pick up a decent torch for less than $50 and it will come in handy for multiple projects in the future. I'm a mechanic for Toyota and you learn quickly on in the auto industry that heat is your friend. Heat that fitting up till it almost gets red and I iwll guarantya it will come apart
