TwinTurbo.NET: Nissan 300ZX forum - Double click the Injector K Value
jerdobi
on June 21, 2016 at 9:00 PM
here is my k-value (i think) 288
posted by surfer31337
on June 21, 2016 at 05:31 PM
You're just hovering to see the tool tip. You need to single or double click the "Injector K Value" to see the value.
rich idle, will soon remove/install injectors w/new o-rings
surfer31337
20:32:05 06/17/16
Your image is not showing (n/m)
YlwPrlZTT
21:25:38 06/17/16
try this
surfer31337
21:50:40 06/17/16
Run a Power balance Test.. Post the Result
Cjw3
22:59:26 06/17/16
here's a video
surfer31337
23:15:42 06/19/16
Thanks.. Just what I needed
Cjw3
09:12:23 06/20/16
thank you for your wisdom, can you help me understand?
surfer31337
19:45:01 06/20/16
Idle is difficult on these cars.
Cjw3
21:09:12 06/20/16
here's another video of power balance test
surfer31337
16:16:11 06/21/16
All looks Good there
Cjw3
17:38:22 06/21/16
i was told this ROM is on the "lean" side, so i tend to
surfer31337
17:07:03 06/21/16
Injectors installed and the ECU K-value
jerdobi
23:04:27 06/19/16
Re: Injectors installed and the ECU K-value
surfer31337
23:17:26 06/19/16
TunerPro will read the ROM dump
jerdobi
23:27:36 06/20/16
Tuner Pro is great Program..
Cjw3
09:29:57 06/21/16
awesome thank u! (n/m)
surfer31337
17:08:41 06/21/16
surfer31337
17:31:20 06/21/16
Double click the Injector K Value -
jerdobi
21:00:03 06/21/16
ok, done, yea it's 288 (n/m)
surfer31337
21:59:31 06/21/16
